I do a fair amount of paintwork on GRP...........anyone have details of the acid etch intended for this?
Is epoxy ok to use without air fed breathing gear?
so does tobaccomost epoxy i have used has cancer related warnings so its up to you..
not nice stuff.
i made my own to prime a 16ft speedboata tin of grey cellulose primer added celly thinners then mixed some fiberglass resin with styrene and added them all together .sprayed on a treat and it wouldnt scrape off
cheap as well
the primer was mixed with thinners then added the liquid resin and styrene 3 quareter primer to quarter resin . mix a small amout up and do a test piece 1stI've got grey celly primer, thinners and got some resin. Is the styrene important? What about activator?
What was the mixing ratio for the parts?
Would this be any good?
http://www.google.co.uk/products/ca...=X&ei=1CMpTuWQBpGs8QORu4mSDA&ved=0CGMQ8wIwAA#
Thankshardener
scott
does fibreglass need etch primer
Am I right in thinking that epoxy based products are not anywhere near as harmful as 2K ones then?
