My Fiesta MKII failed it's MOT and needs 5 holes welded, so I thought I'd better learn how to MIG weld and do it myself.
First I'm having a go at the rear lower corner (see pictures). I've cut back to good metal and removed most paint and sealant. Now, I don't know whether I should buy a repair panel or patch it with a piece. If I go for the panel (see pic), it's larger than the area to be repaired, so do I weld it as it is over the whole corner area or do I cut a section out of it? Or do I cut the whole area back to the same dimensions of the new panel and weld it in as it is? Or do I use a piece of scrap metal the same thickness and cut to size. In either case do lap weld or butt weld?
Sorry for all the questions. Thanks in advance
Regards
Dan
Regards
Dan
I just realised I couldn't shape one piece of sheet steel like that, so it's got to be the pre-formed panel for the job.
Jees..it's sounding tricky - but I'm up for it. Buying the panel will be a bit labour saving what with all the other bits I've got to tack on. So I'll go down that route.
so didn't worry about it looking a bit frankenstein-ish.
I covered external welded parts vulnerable to spray and stone chips with sealant. I also covered most of the the uglier external welds with filler, sanded it down & painted it.....But now the MOT man won't pass the car 'cause he can't see the welds! LOL. Gonna have to cut a lot away and replace with a pre-formed panel and leave the welds bare for MOT man to approve. Sigh. Love MIG welding, but even so...
