Fozzie Bear
New Member
Hi, This is my first post on the forum but suspect it wont be my last.
I am looking for a reasonably priced (circa £200) MIG welder for thin sheet (45 Gallon oil drums etc) I can't afford a PortaMIG and ideally wanted a gasless model as it will not be in regular use. I also have an arc welder which I use for thicker materials so dont need a MIG with a higher current rating.
A lot of forum members recommend the Clarke Pro 90 but that is a Gas only welder. The Draper is one of the only sub 30 amp gasless welders I can find with four current settings and a known brand name.
Does anyone have any experience of this model, which I understand are made in Italy, or can you recommend another make with a 25 amp rating?
Alternatively if I took members advice and went for the Clarke how long does a standard disposable cylinder last for using 0.6mm wire?
Fozzie
Fozzie
