Hi, Awesome Forum for background knowledge ! Cheers everyone for contributing.
I think its ok but I just want to get reassurance before i start to part with my hard earned.
I am looking to do some spraying in 2 Pack. So will be getting 2 compressors, 1 to power the gun and one to supply a mask.
My Q is, will the ABAC B3914 be meaty enough to power the DeVilbiss FLG5 gun.
ABAC B3914 -
3 Hp 150 litre receiver Largest single phase compressor Ideal for most applications Capacity - 430 lt/min / 15Cfm (280 lt/min / 10.1Cfm FAD) Pressure - 10Bar / 145psi Motor - 2.2kW / 3Hp Voltage - 230V Tank (L) - 200 Dimensions WxDxH (mm) - 1400x450x940 Weight - 118Kg
DeVilbiss FLG5
Air Inlet pressure: 1.6 bar (23 psi)
Air Consumption: only 9.8 cfm 368l/min
Thanks in advance and any other comments are welcome.
ABAC B3914 -
DeVilbiss FLG5
. It uses 7.5cfm which is a good bit less than the FLG5 requirements so I guess will be easier on the comp.
