DrGonzoPOW
Hi, new to the forum and am seeking some advice on my car project.
I have recently taken an engine out of an old bmw and found a couple of nasties once i cleaned all the crap away.
It appears that its been in a bump somewhere in its life which has resulted in the front left chassis tunnel (just infront of the front sub frame) being slighty bent and with a large crack in it.
I was given a Clarke turbo weld 130te a fair while back and have never got round to using it but i think with this, its probably about time i learn how to mig weld! Im thinking of using around 1.2mm mild steel with 0.8mm wire and argon gas shield. Would it be best to cut out the setcion and butt joint a cut panel in or could i get away with just placing a patch over the area and do an overlap weld ?
This is a crap pic of the section in question. Ill post a better one up later
I also found a pic of the same car with the same problem that someone sorted but i dont know how the went about it. I would like to get away with not having to drop the front sub frame off but that is probably going to have to be done
Any help would be massively appreciated. And you'll have to talk to me like an idiot cuz ive never welded before. Cheers
Dave
Dave
