I take you have found no such problem Shox doctor?
[Edit] Sorry, read the thread, thin filter material, got it.
here is the dusthood/baffle as promised
its just a sheetmetal hood with perforated diffuser near the bottom
its hooked on with acouple of bits of ally angle bolt on to the fan grills and sealed to the welder with clear tape.
No filter media it just relies on the crud not being able to fall into the fan intake and not being able to turn the the corner and defy gravity
exactly,cause of that im every time turn of welder,cover it....my problem is when its working,and floating dust not eexactly grinding dust....because i turnd of and cover my welder befor doing dusty thing....i have a program for doing ,for example first 4 hours for cuting and everu job that macke dust ,then clean with air compresor and after that turn on welder...remember it s not just the fan air inlet but dust comes in through the air outlet grills when the welder is switched off
that seem cool,it will be ice if have a picMy TIG gets its air through a flat car air filter which is mounted outside![]()
The machines water filter on my plasma cutter is mounted smack bang outside the centre of the intake for the cooling fan! The worst possible place for it. As well as fix up an air filter system like your own, I will move said water filter to a better spot which will probably outweigh the reduction of intake by introducing a filter. Hopefully!As I say Hitch, you can still feel the air flow coming out of the front panel, and to be honest with you, they would have no hesitation with denying you warranty if they found grinding dust in the machine, Ask me who I know. So I would rather restrict clean air flow a little, than restrict cooling by letting the grinding dust get in there and act as an insulator
I've had it fitted to a 200amp TIG for 4 yrs, and it's been used in that time as well, without a fault.
