Hotpoint = garbage these days, throw it away.
On most modern machines they seem to fit the bearings then bond the drum on around them, making it impossible to subsequently replace the bearings.Appears to be a split, screw assembled outer drum, but having never worked on a washing machine I have to ask why that matters?
Do you mean the outer drum is bonded around the inner drum so that it can not be pulled out?On most modern machines they seem to fit the bearings then bond the drum on around them, making it impossible to subsequently replace the bearings.
Yes.Do you mean the outer drum is bonded around the inner drum so that it can not be pulled out?
AI says....
I did one 2 years ago. The outer drum was I think ultrasonically welded so theoretically couldn't be split to get inner drum out. As far as I remember bearings and seal had to be knocked out from outside.AI is not always right! I had hotpoints before where I could buy the bearing kit but the drum was sealed.
I a twist of fate, I happened to take out extended warranty cover through Hotpoint and they had to fit a whole new drum![]()
But good for the environment eh?Terrible when manufacturers do that. Criminal even!
