Should I use E10 or E5 petrol in the lawnmower. Obviously Aspen would be my preferred but at the end of the season, not right now at the beginning. Besides, I need to get the Bank Loan first!
I put E5 in ours, as the remaining in the autumn will stay there until the spring. We’ve got a robotic mower now, so doesn’t get much use, maybe once in the spring.
Well, that looks like it is a good idea so I will get some. First off though I need to go get a petrol can in order to actually get the petrol I need as it has ran out :-(
On a more positive note it actually involved welding before I could actually use it as the handle frame had snapped. Pics to follow later.
having collected a number of chucked out mowers only to find the carb bowl furred up and clogged needing a thorough clean to get them working from ethanol damage, if you are definitely going to leave it over winter with fuel in it then use e5
there was an article out a while ago (in practical classics i think?) where someone tested the ethanol content in fuel and found it to be significantly lower than stated e5= 1% and e10= 3% etc so using e10 wasn't really a problem, however lately another report was that done tested fuel form thew same places only to find the % of ethanol has risen much closer to the stated amount so
as premington states it would be a very good idea to run it out of fuel when storing it especially over winter or you might find nasty surprises the following spring
One of my cars has been off the road for nearly 2 years, parked up with E10 with the fuel warning light on and started fine the 5 times it's been started since then, I did put 4 litres of E5 in it for a treat last week as I will be taking it for mot next week, probably pointless.
Does your float bowl have a drain? Quickest way to run it out of petrol.
e5 in my generator stihlsaw lawnmowers strimmer and norton motorcycle bo.llox to e10 blocking your carbs rotting fuel tanks and lines with ethonol and water in it
