Doesn't it have titanium studs in the end when you take off the plastic caps?My expensive walking poles have got plastic end caps which aren't wearing very well (unsurprisingly). So to the lathe, and some aluminium replacements with stainless screws in the end to provide a bit wear resistance.
They can sit in the cupboard until the plastic ones give up the ghost, then I'll swap them over. Of course if I had a 3d printer I could have just printed some new ones.
Fingers like pigs tits.
I only really use them when I'm hiking (as in backpacking) mainly for a bit more stability, but it seems to make carrying a heavy backpack a bit easier too (I guess you stand more upright and thus engage your core more?).@DanZac
I've seen people walking past my house with sticks but wonder what they actually do, is it easier or faster than without?
Nordic walking I think, exercises the upper body as well as the legsApparently using walking poles uses a lot more calories as well.
Is that the one where you have to walk like you've followed through?Nordic walking I think
I think I'll give it a miss...Is that the one where you have to walk like you've followed through?![]()
I think that’s speed walking.Thank you. I have to say that I'm very happy with the outcome.That looks tidy.![]()
No cheap ikeanice deep drawer bisley
'Nordic' walking?...Sounds like the bloke who did a 'nudist' walk from Land's end to 'J'o'G'......Nordic walking I think, exercises the upper body as well as the legs
Good solution but but some means or other I would not have a gap between the bars that could easily be bridged. Suggest cutting the bars square and a wider insulator between them.Then I had an idea.
Why not use just half of the busbar?
Hence I came up with this solution.
It's half the width, allows easy cable access from either side and allowed me to play for a couple of hours making something that I couldn't buy.
View attachment 540521View attachment 540522View attachment 540523
The central spacer/insulator/clamp is from, I think, a Clarke mig torch part.
Battery conection to each end and the 5 ring terminals can easily be accommodated on the two other posts.
All done with a Boxford, Progress 2G, and a tiny 200W band saw.
