I I remember correctly, that was how to fit Ford 100e little end bearings, they were thin wall, & you pressed them in with a ball bearing in them, then pressed the ball out to true the bearing. Never done it, just what I was told when I rebuilt my Ford special years ago.IIRC some brass musical instrument tubes are trued after manufacture by forcing a series of ball bearing through them.
Thanks for the reply.Good luck is all I’ll say. If it’s a decent quality ball bearing its hardness is comparable to HSS. You’ll do well to “drill” through it with anything. You might do it with carbide, spark eroding could be your only reasonable option.
Either anneal or normalise first for your best chance, should be able to drill with HSS then. Does it need to be a ball bearing?
It's known as burnishing.I I remember correctly, that was how to fit Ford 100e little end bearings, they were thin wall, & you pressed them in with a ball bearing in them, then pressed the ball out to true the bearing. Never done it, just what I was told when I rebuilt my Ford special years ago.
Yes it has to be a ball as it has to be pulled around à bend in the pipe.
That's why I suggested using pushed in the tube balls . they will simply run with any bends with ease and there is no chance of the balls breaking off the pulling bar , rod, wire or cord to become stuck half way along the tube . Annealing the tube or even getting it red hot if it is a thick walled tube would help too.Would the string pulling the (single) ball not try to cut the corner and dig into the inside of the bend?
I would think it might need multiple balls to keep the rope centralised.
What, one of those newtons cradle things with 5 balls in a frame? Can’t see a problem with thatGood shout.
Just don't go searching for an adults toy with metal balls on a string.
