sack truck and walk them...Good idea but I can't lift them anymore![]()
I'm looking at cutting out a 2x3 meter lump and concreting that amount. I could just keep going to the full length as it's all crxp but I don't have the time or want to ***** a load of money on a drive that's getting replaced at some point in the next years.
As for the council, they are predictable useless and haven't fixed the knackered tarmac, I'll escalate things probably and see what they do...
cold tarmac can and is at our place drivin over normaly 2 mins or even as im doing it only thing i do when ive wacked it down well is brush a bit of dust/light stones off the side of the road and brush it over the tarmac looks a bit siht but stops the tacmac being sticky and stickying to the tyresWe can't stay off it for even a day. We have four cars going in and out everyday and nowhere else to park as it's a narrow lane. This is turning into a right hassle.
ive even had large lorrys full of rubble drive over after a few mins and its ok
only thing that helps makes the job easyer doing it when its 15oc or higher as the cold tarmac is warm and i just roll the bag about to brake it up before opening (as if you just dump the bag out you spend ages breaking up the lumps so spending time bending and rolling in the bag is well spent
clearing the hole must not be wet i use a sthil blower to get any dust and loose stuff out
and if possable no rain for a day the longer the better
i was only thinking hes going to use the cold tarmac for the tarmac area not the concreat driveThe good cold lay tarmac is actually hydro curing. But even the cheap stuff is expensive in Comparison to hot lay.
If you have a friend with a tipper van or a trailer I would be inclined to just collect 1t at £150 a tonne. As opposed to Coldlay at £550- £1500 a tonne
just a point hereIf price is a key point. Asphalt is usually cheaper than concrete as there is a significant reduction in prep time. Also unless you pay extra for rapid cure concrete (which is also harder to lay due to curing time) then you have 7 days to stay off it but tarmac can be as little as an hour.
They might play the Ransom strip malarky on you , they have done their bit tarmacking up to the Ransom strip .I'm looking at cutting out a 2x3 meter lump and concreting that amount. I could just keep going to the full length as it's all crxp but I don't have the time or want to ***** a load of money on a drive that's getting replaced at some point in the next years.
16 yrs ago in mud July I tried getting a couple of ( in my 3/4 ton trailer) loads of hot 20 and 2 loads of 10 at a local Tarmac plant ..The good cold lay tarmac is actually hydro curing. But even the cheap stuff is expensive in Comparison to hot lay.
just a point here
we dont drive on freshly laid tarmac thats laid on a rd why would we drive onto a drive thats been freshly laid
as goes for properly done and set its stay off it for 24hrs
as its been made very clear its a conservation area its like for like or it gets refused ( post 11 )
They wouldn't let me on site even though I had steelies , overalls , gloves ,yellow vest , hard hat & an eyewash pack ,. stating i wasn't qualified / trained to be on site as i had no safety certificate ...... But they could deliver each small load for £600 plus VAT..
In the end I had half a pallet of cold cure delivered by a locak builders merchant . Left it out in the sun for a day and around 3 the next day laid it running a small trench wacker over it after a spray or two of diesel on the plate sole and then fine spray hose pipe cured it , , also used liquid bitumen to seal the edges .
Take the family on a two week holiday, leave all your cars at the airport…get a man or two to fix drive. Or stay in the UK. Sorted.I'm not bothered about the conservation part of it as I'm just fixing the existing drive but if/when it gets redone properly it has to be "in keeping with the area" so gravel: no good for motorcycles, cobbles: very expensive or something else. Block paving is definitely not allowed.
This is a right PITA as it was the councils crappy road surface breaking up that started the driveway crumbling.
