JonnyAlpha
HI;
Just got hold of a second hand Clarke 160EN Turbo from the For Sale section on this site and need a bot of advice on maintaining it ready for welding.
It has been sat out of use for about 18 months and the seller has advised wisely that I should remove the welding wire that is currently in the machine as it has rusted. Again I think on advice from him I'm going to snip off the wire near as near to the back end of the hose (wire feed mechanism end), and pull the wire out through the nozzle end with a pair of pliers.
I am then going to remove the wire reel unless after removing the top layers its OK of course.
The shroud is very rusty should I replace it? How often do they need replacing and or is it a good idea to have spares on hand whilst welding i.e. do they get damaged?
Do i need to replace the tips - UPDATE just read on the weldequip site that the Tips are copper and transfer current to the wire so looks like thats a YES replace them as copper corrodes.
What should I clean the wire feed mechanism with WD40? or just a dry cloth?
Once Iv'e removed the rusted wire, replace the shroud and possibly the tip if required it should be good to go?
Thanks in advance.
Thanks in advance.
