And they had nicer motors.I was always taking my old mum's twin tub washing machine apart, but in fairness you could get all the parts and keep em going for many years, don't think i'd even bother trying to mess with a modern plastic-y automatic type thing tbh
wellll...the leak out of the external weep hole is the usual clue...I found out the hard way that the engine in my Ford Explorer has an internal water pump. The seal let go with no warning and dumped coolant into the engine. No warning signs or indicators, - pow - no more car. Who designs this stuff.
I broke the brand new oil drainer at work last night.
Went to step past it, caught the level tube with my boot, which snapped the level tube top and bottom, send a spray of oil 2 metres across the floor, and resulted in a little fountain of oil from the remains.![]()
Seems to be the thing I hear about failing the most - certainly had on mine. I don't know whether it's galvanic corrosion between the aluminium spider, the steel shaft, and the stainless drum, all in a nice damp environment. Or simply powdered washing detergent doing all the work as it was plastered all over mine from it's previous owner - I've always used liquid detergent.A bit of amateur washing machine fiddling today. Drum rattling about giving the impression the bearings had failed. Ordered some and stripped it down to find the spider that connects to the drum had broken in 2 places. Could have replaced that for £50 but the found the metal drum had been wearing the plastic drum as it rotated. Looked to be a potential leak point in future, so new machine required.
Although, if it's exactly the same, it will probably fail in the same place as the originalOn the plus side if you buy the same model you’ve a floor full of spares.
I'd did seem to be corrosion on the spider had caused it to fail, shame because the rest of it was perfect, well until the plastic drum was damaged.Seems to be the thing I hear about failing the most - certainly had on mine. I don't know whether it's galvanic corrosion between the aluminium spider, the steel shaft, and the stainless drum, all in a nice damp environment. Or simply powdered washing detergent doing all the work as it was plastered all over mine from it's previous owner - I've always used liquid detergent.
Different machine but may stick the motor and control panel on ebay.On the plus side if you buy the same model you’ve a floor full of spares.
How does it feel to be so popular at work![]()
When I was an apprentice in the 60s the oil drainer was emptied using compressed at at 90 psi , it had what was supposed to be an automatic valve at the bottom of the “funnel” which didn’t always work . I got caught once when it did its gusher impressionI broke the brand new oil drainer at work last night.
I've once had a 1" hydraulic hose exploding in front of me, I was entirely lubedWhen I was an apprentice in the 60s the oil drainer was emptied using compressed at at 90 psi , it had what was supposed to be an automatic valve at the bottom of the “funnel” which didn’t always work . I got caught once when it did its gusher impression
I got lubed as an apprentice, it took 6 of the workshop staff to do itI've once had a 1" hydraulic hose exploding in front of me, I was entirely lubed
The last day prior the August break, we were cleaning the machine shop.I got lubed as an apprentice, it took 6 of the workshop staff to do it
Except for the spider and drum assembly . It's becoming the case that if your washer is over 6 yrs old you're better off buying a newer more modern machine with a 2 yr warrantee on it .Keep checking the family heirlooms .. cutting oils have a very nasty habit of making for scrotal dermatitis, You may have dermatitis as a result of the soaking on your feet as well .The last day prior the August break, we were cleaning the machine shop.
At some point we had to move a lathe tray and we discovered that the waste coolant tank was full at top .
The smell was awful, we moved out from underneath the lathe, but we have lift it up at chest hight to move it outside.
Who was the man of choice to do that?
Obviously the not even 50kg guy and another colleague, the coolant was splashing here and there while moving the tank .
I couldn't really manage to keep a 50kg tank filled with 200+ litres of coolant in balance.
My colleague thought I was trying to get him socking wet and he didn't just left his side of the tank, he tilted it towards me.
You already know the outcome...
The shop was flooded in rancid coolant, I have completely I can't even describe I wet I was.
Had to bin everything I was wearing.
My feet never been the same, since that they have like freckles.
Tried everything thinking they were dirty but those don't disappear.
It happened 3 or 4 years ago already maybe more.
No it's fine or at least till nowKeep checking the family heirlooms .. cutting oils have a very nasty habit of making for scrotal dermatitis, You may have dermatitis as a result of the soaking on your feet as well .
Nothing has been said.How does it feel to be so popular at work![]()
