Your repair you said was abs, which is very easy with acetone slurry. I've done worse damaged, bike fairing repairs with it.Use a soldering iron. Poke it into the crack, melting both sides and then while it's molten, smush it back together. If you want to reinforce it, aluminium filler mesh does an excellent job.
See this post
If you have the old panel clip a bit off that. I find solder station heat guns are excellent for plastic repairs as you can totally control the temperatures.I will need to find some PP filler rod from household junk items..
Provided you're an octopus or have a helperYour repair you said was abs, which is very easy with acetone slurry
You can always trim a bit off the same panel from the inside back edge with a stanley if you need some filler, but you're aiming for a near full penetration fusion repair if you can get in at it, rather than a surface fillet.Yes soldering iron plastic welding looks the best option, I will need to find some PP filler rod from household junk items..
Plastic welder? The type which uses the staple type affairs.
I dislike the staple types, seems a bodge. Ok as reinforcement but not on its own.Plastic welder? The type which uses the staple type affairs.
Is that Welsh for "higher"?elwvatwd
