Guineafowl
- Nairn
Looking for six fixings for 4x4 posts onto flat concrete. Screwfix do these ones:
Any good?
Any good?
I did the first time I used them, but at 9 quid each is it worth the hassle, of buying steel, cutting steel, drilling steel, welding steel, painting steel. Unless of course you already have it lying around.why not make your own ,,,
yours can maybe only have two sides to let water drain to stop rot or at least slow it down , be made of heavier stuff , with a base larger , smaller or off set to suit the job better , be thicker to last longer , and of course give you the satisfaction of being your own work , now if thats worth it or no is totally up to you ,,,I did the first time I used them, but at 9 quid each is it worth the hassle, of buying steel, cutting steel, drilling steel, welding steel, painting steel. Unless of course you already have it lying around.
