4.5 Volt DC.Put a meter on s3?
Great. On new board or old one? I seem to remember you saying you were changing the board as well as the switch? Remind me what was wrong with the board.4.5 Volt DC.
The pump works wired directly.Great. On new board or old one? I seem to remember you saying you were changing the board as well as the switch? Remind me what was wrong with the board.
That makes complete sense.The pump works wired directly.
So I know the motor and pump are operational.
If I close S3 and S3, the pump doesn't run (I tested the reed switch, and it was intermittent), so it needs a new reed switch.
Haven't tested the pressure switch with pressure, but it's closed circuit, which I presume is correct, and opens if there's too much pressure, stopping the pump.
So assuming the pressure switch is ok, and knowing the reed is kaput, with the reed circuit jumped closed, the pump doesn't run.
There are no other external components, so I'm condemning the circuit board.
Feel free to correct me or suggest any other tests.
It's sending 4.5 volts to S3 and S1.I notice that it has a PCB mounted transformer, the maroon lump.
These are notorious for failing. Well worth checking it first. They're readily available.
