My first post, and my first day welding as my Draper 70049 MIG Gasless 120A inverter arrived today - I found this forum after I'd ordered it, oh well, I'm making the best of it
Previous welding experience was about 5 minutes with a pal 10 years ago, and it spattered and spat so much and I couldn't see a thing - it didn't encourage me to weld again...until now.
Forgot to take pics until later on, so have already attacked the welds with the grinder (somewhat ham-fistedly).
I did the obligatory burning of my initials into a piece of sheet, and a couple of not very straight lines to check it was all working and make sure my PPE was all good - it was.
Welding practice kit off Amazon, small postcard sized 0.8 or 1mm panels, the middle pops out and then you can weld it back on or at angles. I'm assuming that's what you do, it was just a box of steel with no instructions...I suppose you could weld it in-place as well.
First up a fillet weld about 8cm long, I tacked both ends first to stop it deforming...which seems to have worked well.
Would love to say it was then a single smooth movement, but it was very stop start with the arc either stopping or electrode getting stuck to the material. I think I was having difficulty judging/controlling the distance from the work piece
The weld itself has gaps and the electrode was wandering all over the place and from the stop starting.
Played with the welding mask a little (auto darkening) and turned the wire speed (and indirectly the power) up to ~30% (was being cautious about blowing the fuse/breaker, 16a into a 13a plug)
Next, I flipped it over and welded the outside of the same edge. I found it easier to see what I was doing and less sticking.
Next up some 2mm steel sheet offcuts and butt welding two pieces together. Felt brave so turned the wire feed/power up to 6 (out of 10).
This was MUCH better, even managed to do some little circles with the electrode - I was quite pleased with the way it turned out.
Then I looked around the back and am less sure it penetrated through. Suspect I need to turn the power up.
Anyway, thanks for reading, I'd be interested in your thoughts on my first welding.
