zzr1200
Working at 650 ft on open steel work.
- Glapwell, Chesterfield, Derbyshire, UK
I also don't disagree with you, I know mcb have type A/B/C/D power curves, which are for different initial rush draw currents for motors/transformers, so being as there are only a few countries that possibly use our system of wiring, and most others seem to use a system where each outlet is protected by a single mcb ie:- consumer unit mcb>cable>2/3 pin continental socket>a plug (no fuse)>cable>table lamp.The 13a plug on the table lamp should have a suitable size fuse to protect that cable. (Ie, 3a or 5a)
You can't do that with the blue industrial plugs as they don't have fuses.
I'm sure there are plenty of table lamps with 13a fuses fitted because a helpful son-in-law had fitted a new plug and left it with the fuse it was supplied with. Just waiting for granny to adjust the chair and fall asleep with a chair leg crushing the cable...
A quick Google suggests 7000 house fires a year with 89% being caused by electrical faults. Most common fault being an overloaded outlet followed by lamps and lighting..
We'll agree to forget places like India where it's a free for all, Ratsnest system.....
Now my questions.........
Do the MCB Manufacturers make country specific mcb's or are all mcb made the same, and have a 30mA spec?
So why wouldn't a 32 amp mcb protect a circuit with a 16 amp item supplied by it, or is just the cables current capacity that controls the mcb rating.
I have in the past accidently cut a 1.5mm extension cable before, the mcb has tripped but the plug fuse was ok???
