Still cheaper than taking the head off, or buying special tooling that you'll only use once (unless you can find second hand or an ebay special).Yes, I've found some, but they are quite expensive (£100 or more - per injector!) and how do you know if they are any good?
Yes, I've found some, but they are quite expensive (£100 or more - per injector!) and how do you know if they are any good? It's another option if I can't get them out myself.
I've looked into this and there are some not too far away, but they are all expensive, at £100+, per injector! It's an option, but a last option for me.
its probably finding the right person who is competant and can be recomended is the hold up, we have all had experiance of the "expert" turning up with all the gear but maybe not quite the experiance to do a job(in many trades) , I had to take a one injector back out of a set serviced by a well reputed company , diesel leaking out the top cap after full service/test , refitted ..still the same, ended up buying another as they were nt to be trusted and it was a few hours stripping and refitting again. yes they offered for me to take it in, but as they lashed it up twice I was nt about to be told its duff , as they should have found the fault after testing twice, then it would be xxhours labour plus new injector ,plus vat, would have been in the late hundreds by the time they finished. so I understand the trepidation , but sooner or later you have to bite the bullet .We do it in our workshop - we got the Pichler kits here (most of them).
But I charge more than a £100 quid a port to extract injectors - the cost of the tooling and sacrificial threaded adapters - plus the time it takes - makes this a more "than a £100 an job".
£100 quid to get a stuck injector out - looks cheap to me!
FoMoCo, Peugeot Citroen.
The world's gone mad I tells ya.
please put up pics/details on how you get on , appreciated. ps good luck ! fingers crossedI was meant to be off this week but got called in to work.
I think this thread jinx'd me.
....! not down in southampton for a day of onsite work are you. ??Oh it's out, van's done and running.
....! not down in southampton for a day of onsite work are you. ??![]()
ah well, enjoy the breakNo, i'm very much in holiday mode so doing as little work as possible. To the point that i told them i'm not coming back after i get back from holiday.
It's hard to believe how stuck they get..OK, long time no post, sorry about that. I made a tool to grip the injectors (see photos) that takes either a slide hammer, or a lever. It fits and grips the injector very well, but unfortunately, even with using this, they still refuse to budge. I have used it to hammer (up) and used a two metre lever to try to lift them out, but still no luck (initially I used a wood/metal base for the lever, as per the photo, but have now swapped this for all solid metal, but it didn't help), so it looks like I'm going to have to find someone to get them out for me. - especially as one of the injectors has come apart, so the lower section will need specialist tools and knowledge to get out. I don't like giving up on anything, but I've done all I can now.
Can anyone recommend someone they've used themselves? I will need someone who can come to me, as the van no longer runs. Thanks.
