Some of the German stuff did/does use a spread sheet rather than a schematic or diagram. It just lists out the origin and end point, with columns in between for connector numbers if they're not direct, pin outs at start and finish, wire gauge, colour etc.Thats a new one on me, Panel wiring I understand. Spreadsheet I understand
Panel wiring spreadsheet, Que?
What are you hoping it will do for you?
That sort of thing yes, I just wondered if there was anything already done which I could edit/adapt.@Cato are you looking for something like this?
If so I can knock something up for you.
I did all the extra wiring, lights, horns etc. on my last bike in blue tri-rated because I had rolls of the stuff..... trying to ignore that time when he rewired someones gs1000 with entirely black wire because he only had black wire on the reel. It was ok though as I fault find with meters anyway, and the owner was colourblind![]()
Loco wiring is all black.....we'd have run out of colors.trying to ignore that time when he rewired someones gs1000 with entirely black wire because he only had black wire on the reel. It was ok though as I fault find with meters anyway, and the owner was colourblind![]()
I think the bugger did fire alarms in Glasgow.IIRC an interview with Rod Stewart, said he worked at an alarm company, before he hit it big, wiring the things, and he was colorblind. He apologized if he made any defective ones.....![]()
When I built control panels, most of the wiring was blue as that was the BS EN 60204 specified colour for DC control circuits, with markers on each end for identification.Loco wiring is all black.....we'd have run out of colors.
Boot markers at each end identify the wire.
I always wondered why machines were filled with blue wiring!When I built control panels, most of the wiring was blue as that was the BS EN 60204 specified colour for DC control circuits, with markers on each end for identification.
Our industrial panels were the same as what you've pictured.When I built control panels, most of the wiring was blue as that was the BS EN 60204 specified colour for DC control circuits, with markers on each end for identification.
It's called a 'wiring ladder' and beloved of the Germans - hated by everyone else!Some of the German stuff did/does use a spread sheet rather than a schematic or diagram. It just lists out the origin and end point, with columns in between for connector numbers if they're not direct, pin outs at start and finish, wire gauge, colour etc.
Clearer and easier to use than schematics once you're used to them, much quicker to fill out, and you can add notes or updates without making a mess or starting again.
Thank you, I couldn't for the life of me remember what they were called. The first time I came across them was 1989 on the base power generation panels and as the base was a typical Gov't contract it was a right mish-mash. The prime movers were Cummins, Ambac supplied the governors, the heat exchangers were Norwegian, control and distribution panels German etc. The only effective way everything could be pulled together was with text only spread sheets and I found they were very effective and much easier to follow than schematics in 4 or 5 different languages with translations and standardised symbols that were anything but standardised.It's called a 'wiring ladder' and beloved of the Germans - hated by everyone else!
I've got lots of examples on my work PC but no 'template' that I'm aware of.
I can see the benefit in that case, but for most integrated systems, the visual (and in some cases, interactive) schematics are quicker - although JLR's connector library is similar to what you describe and I do find that very useful, rather than chasing a signal across multiple systems!.
Wire chart (in JLR-speak) for a random BCM connector
I want to use it for making up custom looms, so it'd be a much condensed version. From the first draft it'll be much easier for me to make changes/additions if everything is set out as a point to point list with the basic descriptions. A schematic with graphics would be quicker and easier for larger, more complex stuff, and also be repeatable, but the stuff I put together is simpler by an order of magnitude and doesn't need to be repeatable.
Terminal/pin number - wire gauge - wire colour - connector number - pin number - wire gauge - wire colour - unit/item/device - terminal/pin number, column for any splices, and so on.
The other thing is I won't need to pay stupid amounts for a subscription to software that I'm only ever going to use about 15% of the features from to create schematics which provide no more information than the list style.
I have the same, but with a sheet of 2mm thick white plastic glued to the face and I use self-adhesive cable tie tabs stuck wherever needed to hold the cables, and make notes on it with a whiteboard marker. Once the loom's done peel off the tabs, wipe off the notes and it's ready for the next job.My go to for harness wiring is a sheet of ply with nails in it
Bob
