twatting under pressure not recommendedI have had to pump it up to 10T and hit the lower plate on the press with a hammer t
I had a 20 ton floor press from Machine Mart. From memory there are two models... an economy model (chinese Manufacture) and premium ( Italian) which was the one I purchased. I had heard rumours that the economy struggled to deliver the full 20 tons.Hi everyone, I am considering getting a hydraulic press nothing to excessive it’s mainly for doing wheel bearings on cars etc, but I was wondering what would be the ideal tonnage for my hobbyist workshop
Thanks as always
i had the same issue but the part wouldnt give under full pressure however i got told some advice about using the blow lamp and then press it outtwatting under pressure not recommended
my son did this and the result was a bent pin and bent cross supports when everything fired out sideways
doesnt take a lot of heat to make the difference, just a sudden bang! and new pants are needed!i have a clarke press but i also use a blowlamp as well but have advantages when using the press
ive known some not even give with the press but the usage of the blowlamp helps to free it
www.frost.co.uk
