Blimey @John_aero that sounds a bit drastic! But I’d imagine it would solve the problem!
What are you planning on using it for?
In fact what does everyone use them for?
I understand why it might be useful to machine a face nice and square with a bore as well as the myriad of other functions you see on the instructions but I wonder if anyone puts them to use regularly?
Put your handbag away. You're practically arguing the same point.No point arguing with the China hobbyist and Argoshield that has a Phd in everything.
What do I know.
You've completely missed the point of the whole post and obviously the kinematics of machine tool tapers.Put your handbag away. You're practically arguing the same point.
It would surely be self evident that an ISO50 taper is stiffer than R8 - they don't make big machines for bragging rights, but if you don't have an ISO50 spindle to stuff it in, you can't possibly leverage the benefits of its stiffness. If you made an adaptor to fit an ISO50 tool in an R8 spindle the extra length would far outweigh the rigidity you'd lose from just machining it back to a parallel 20mm shank.
A 20mm shank can still do plenty of work, as can an R8 tool in a Bridgeport, just significantly less in a single pass than an ISO50 taper, but it will get there eventually.
My apologies. When you said:We are not comparing ISO50 to R8. We are comparing a parallel shank to R8.
Ring Wohlhaupter (allied tool)Amway just back on to the UPA3, i have found one with the red dot but has a different arbour. Can the R8 arbour be got easily or is it easier find a generic one and modify it to fit?
They are quite helpful
