On your propane rig, did you switch the torch tip to one for propane ?I use multi-stage on my oxy-actylene kit, and single-stage on my oxy-propane. I don't notice a great deal of difference, other than I tend to blow out the propane flame with the oxygen more often than I do when using O-A. I don't know whether the two things are related? Perhaps multi-stage on the oxygen would be smarter?
Either way, propane is cheap, and you're only cutting / bending. Either will do the job.
Yes, I have an entirely separate torch on the propane rig, using only PNM tips. I have, however, made the mistake to which you allude in the past, and it is an absolute nuisance.On your propane rig, did you switch the torch tip to one for propane ?
