As carbon said, if the oil is milky you have piston or seal problem.
If it is overfilled that suggests that quite a lot of water has made its way into the piston housing.
If the low pressure seals are gone you will usually see water dripping under the pump but not if the drain holes are gunged up.
Some washers are prone to making the oil milky due to a poor seal design. The old KEW 3 piston pump was like this. You could fit new seals and pistons and in a few weeks the oil was white again!
But Kränzle is a good quality pump and it shouldn't happen under normal use.
It's not hard to take off the cylinder head and have a look at the pistons and seals.
A common cause of damaged seals is running the pump dry or leaving it running on bypass too long, the water gets hot as it circulates inside the pump and quickly damages the seals.
If the pistons are ok, when fitting the seals install them into the cylinder head. Do not install them on the piston and replace the cylinder head.
Had one company deliver a machine to me after they replaced the seals and couldn't get it to work. There fitter got irate with me when I started to take the pump apart to find the fault, claiming that he'd fitted new seals and it made no difference. He'd fitted the seals on the pistons then refitted the cylinder head which cut every seal inside into at least two parts, shame he missed the crack in the back of the cylinder head due to frost damage. So seals alone were never going to sort that pump out
The oil turned up earlier.
I drained the old and refilled. It went milky-ish instantly and hasn't got much worse since.
I guess I'll run it for an hour or so and then change it again and see what's what.
Im tempered to take the front off it and "have a look" but, unless you have experience, you never really know how much ware on parts is acceptable.
I mean, I could look at the pistons and they're not going to look brand new, as it's 5 years old, but I, personally, won't know what's an acceptable level of ware and what's too much.
And, as someone (probably) said, replacing seals on a worn face often just ends up in chewed seals.
So, yeah, I'll run it a while and then change the oil again and see what happens then.
Used to see that a lot possibly 30 years ago, some looked like there were spined shaft’s.The stainless ones can get scored along their length, again fairly obvious though it rarely happens
The kranzle ones have a thin black ceramic coating maybe 0.5 mm thick that can chip some of the karchers have a very similar piston. But I have seen some more recent karcher’s without the coating again.The piston will usually be chrome plated steel or solid stainless steel or ceramic sleeves on a steel centre.
I removed all the seals, apart from the last one on the motor side (which is just a flat washer)
I get the impression that the the bits that do the work are in the brass carrier -
The one i left in would be #33.
I think its probably #32 that does most of the work?
In the videos ive watched, #31 seems to be hard to get in/out of the brass carrier. I could just slide it in by hand, without effort.
