Yes please!I do know one who might be interested. I can ask him if you want?
No clue I'm afraid. From what Ben said the 655D is completely different to the 655C. I did reverse engineer some of the pins so I can dig out those notes if I can find them.Ed, do you know what colour wires supply the ignition live and earth to that instrument panel? I need to tap in to them on my 655C for an aftermarket temp gauge. I have the wiring diagrams but can't make sense of them!
Ah, Veglia Instruments...A rear view of one of these might be useful . .
@ejtrent if he's still on here.Somebody who does guitar pickup winding, should be able to rewind a couple simple coils like that.
That why (I think) I said, sort of like, didn't know what else to call it.Being a bit of a pedant .... it's not a moving coil instrument .... the coils in this appear to be static .... so its 'moving iron' rather than coil.
Looks rewindable to me.
Oh I know it could be re-wound - just not something I want to do!Some lathes are slow enough to wind the coils on them >
Wonder why the enamel is different colours.I assume that both coils are electrically identical,
It does look like the windings are configured in the same way as the diagram I posted above (random one found on the internet).The readings sound weird. I assume that both coils are electrically identical, because that makes sense to my mind.
Physically they seem the same.
There's a very slight mechanical biasing when the gauge is vertical because of the butterfly plate at the pivot point on the needle (the gauge is mounted vertically).is the pointer biased to the centre and one coil pulls it down the other up?
They appear to be - I have reflowed, cleaned up and reflowed them again. It really looks like a winding has broken somewhere inside the winding which ties in a little with what Ben witnessed in the digger. The gauge was working fine and he had about half a tank (ironically whilst doing some tidying up at ours before our wedding) and then the next time he glanced down at it it said full which didn't make sense since fuel doesn't usually magically appear.Are the coil terminations OK? Coils clearly have not been cooked.
My suspicion is perhaps they are different grades of wire and thus allow for different coil resistancesWonder why the enamel is different colours.
Good point. I'd forgotten the config. diagramIf you make the assumption that the sender goes open circuit at one extreme and short circuit at the other (for the sake of explanation) then in the short circuit case the "full" coil in the diagram is eliminated as both sides are now grounded so the high side coil (empty / left on the diagram) is the only with any current flowing through it so pulls (one assumes) the needle towards it. In the other situation where the tank is full and the sender goes open circuit then that whole path is eliminated from the diagram and both coils get power flowing through them but things must be biased in such a way that the needle points at full.
Isn't that a moving magnet or iron or whatever, with stationary coils?
