hotponyshoes
- Somerset. Uk
I'm looking into the idea of putting some text onto some horseshoes.
A bit like this sort of thing.. but a bit tidier..
These shoes will be made from relatively soft materials like aluminium, copper or brass.
So I'm after recommendations on a suitable machine to do this job.
Capacity of the machine won't need to be any bigger than 200x200x20mm (and the engraved area much smaller)
I'm not sure if laser is much use at making a decent mark on those materials?
If not, I'm thinking machining with a 1mm ball cutter to a depth of 0.5mm will give me the look I'm after..
They can all be engraved in the same location so I'd think a couple of locating pegs on the bed and some over-center clamps should do for quick loading?
My first concern is these shoes are all handmade so the thickness is going to vary a bit.
How do I account for that?
Any desk-top size machines that come with a probe to recognise the height of the inserted material?
Or twin heads (or tool changer) so I could machine a flat area then engrave the text into that area?
I'll probably run the top surface over a belt sander first. Maybe the bottom surface as well but I don't really want to be measuring each one to get them 0.1mm perfect so need some way of coping with the variation if the text is only 0.5mm deep.
