Martin Hocking
- Norfolk
I’ve been molesting my American pick up to deal with some issues- mainly rust related, though one of the non rust related tasks is sorting out the tow bar wiring. It’s a bit messy, it’s got at least two too many sockets, all three of them a bit crusty and wiring that already looks like I did it in places! I’d tell you if I had honest I would!
So the pick up is a 1998 Ford F-150 and came with a factory tow bar when it was built four score and seven years ago…
This has a main wiring connector which deals with the rear lights and trailer socket.
When it was imported it would appear that a fairly hasty conversion to a double seven pin uk tow bar set up. With a caravan relay thing tucked up in the near side rear light.
What I’d like to do is fit a single tow bar socket and make it a neater less convoluted arrangement.
As I remember it the current lay out went with a 12v ignition live tapped out from the us trailer socket and an extra 12v constant live plumbed in. Both running to the relay thing in rear light. Feeds are then plucked out of the lights for the brakes and indicators etc.
(I’m pretty sure that’s pizza dough not leprosy before anyone suggests hand cream!)
What I wonder is whether it’s possible to make better use of the original Ford wiring for the American socket?
A quick internet search came up with this info on wire colours:
color code for the factory sevenway
white = ground
Blue = electric brake
orange = hot line (Battery (+) ignition controled
brown with white trace = running lights
yellow = left turn
Green = right turn
last one is backup wanna say its black with a green trace
(Taken from THIS forum thread)
Which seems to tally up with what I have going into the socket.
So to me it seems like most of what I need for a basic seven pin tow socket is there in the Ford wiring, and the extra 12v feed means a 13 pin is pretty feasible too. Even though I think I’d rather die than have a caravan it might be useful all the same!
I know in the states that brake and indicator lights are share a pin in the trailer socket is there something different in the way the circuit functions that means it won’t play ball with a uk socket? I’d be using the electric brake wire for the brake lights.
I’m doing my best impression of someone who has a clue so any advice is greatly appreciated…
white = ground
yellow = left turn
Green = right turn
