There is a device that you let into the floor base that has a float operated flap that seals off any back flow from outside it's used for both toilet and waste water products . I recommend you have an air tight man hole cover over it just incase you do need access in the future for some reason or other.Today the house had all furniture moved outside before the floors were scrubbed with disinfectant.
Looking around, the water has been under every piece of furniture but everything is on 7mm "legs" - and the water didn't reach 7mm so the bottom of the units didn't get wet which is a massive relief.
Reshaping the ground outside is the best solution but unfortunately it's not an option.
I'm in the middle of 4 cottages and we have a 12ft wide footpath outside.
The far side of the footpath was a dry stone wall with a gate for humans and cattle (and access to the local smallholding) until the land was sold off 5 years ago to developers.
The gate in the old stone wall was removed by the developers when they made a continuous brick wall, rendered and painted white.
Flash floods in the past would come downhill from behind the cottages, around to the front then continue downhill into the smallholding gardens / fields.
With the new wall in place there's nowhere for the water to drain to.
A higher front step would be be an option but if the water is at that level, it's higher than the floors inside the house. The shower cubicle drain is lower than the floors - sealing the front door would still allow water to rise up through the shower drain and flood the house from that direction.
I need to have a trip to the council and ask what they can do - I'm not even sure if adding a drain outside my house would help as flash floods here are severe and cause problems with drainage everywhere...
The developers won't reinstate the gap in the wall as that piece of land is now a driveway to the underground carpark they built and they won't want that flooded.
its up to the cottages to create your own drains nowToday the house had all furniture moved outside before the floors were scrubbed with disinfectant.
Thanks for all the info, I should have said - the cottage is in Portugal so l need to see what the laws are here.
The problem isn't that someone has diverted floodwater here - it's that the developers have blocked up what used to be a gap in their boundary wall that used to let surface water flow downhill from my land onto the property they bought / developed.
Fitting a drain or french drain isn't an option, it would need to be over 200ft long and cross several neighbours properties...
The 12 ft wide footpath is an odd situation, the half nearest the house is my land, the other half isn't (presumably it used to be a public footpath for the last cottage but they use access from the other side). My neighbours won't go for a drain as their houses are above the flood water level.
I'm not confident that a one-way valve in the sewer or shower drain would be 100% effective - it will have to hold water for several hours so even a slow leak would allow the shower tray to flood the house.
Fitting a higher front door step is pointless without fixing the shower.
The float one way waste vales are very good , do a bit of research ask questions about back leakage , see my other post about a sump that could also be the answer for the drains .Thanks for all the info, I should have said - the cottage is in Portugal so l need to see what the laws are here.
Depending on the shower plug hole you can sometimes remove the plug hole inner grid and insert a six to 10 inch tube down into it , similar to a commercial restaurants kitchen sinks plug hole over flow tube , your pipe would work in reverse so long as you remember to reinsert it after each shower .Thanks for all the info, I should have said - the cottage is in Portugal so l need to see what the laws are here.
Move and make it someone else's problemThe root of the problem is standing water at the front of the house now has nowhere to drain to so it rises until it floods into my house via the front door and shower cubicle.
The pool of water this week was nearly 200ft long covering the footpath at the front of my house and the nearby road. The water eventually drained away - there are 2 drains about 150ft away from my house - at least 1 was partially blocked with leaves and debris after the floods, Storm sewers in many areas could not cope.
Putting a sump outside (or inside) the front door with a float operated pump would - in theory - work but 2 issues :
There is nowhere to send the water apart from back outside the front door where it came from (I have houses on 3 sides and the new brick wall outside the front door).
The volume of water that accumulates during a flash flood is huge, I'm guessing the pump from a fire engine would be noticeable anything smaller would be a waste of time.
The only solution is to stop the flood water from collecting outside my house but that needs action from the council...
The shower outlet is an oval pipe, an open tube there would stop backfilling from the drains but would also lead to smells and allow wee beasties to come up from the sewers.
A shaped oval "cork" might work but it would need to be 100% watertight, also tight so the pressure from the drains during the floods wouldn't pop it out of place.
Any cork would also stop future flood water draining away down the shower so it might cause more problems than it fixes.
i need more info if you could can you draw out what you have via paint or another programThe root of the problem is standing water at the front of the house now has nowhere to drain to so it rises until it floods into my house via the front door and shower cubicle.
Sadly 5 or 6 people died - seriously bad conditions.Portugal has been hit hard by flooding in the past month.
Reservoirs have been around 20% critical level for 5 years due to droughts (I’ll add a photo I took last year if I can find it).
Rains in the past few weeks mean the reservoirs are now full to capacity and are having to discharge water to stop levels overflowing
Flood concerns after Algarve dams fill to brim, with more preventative water releases looming
Flood concerns after Algarve dams fill to brim, with more preventative water releases loomingalgarvedailynews.com
Storms in the north last week destroyed several cities
Crazy times
