Same experience...soil pipe holes cut with my trusty 240v SDS DeWalt ..took a whole day to cut 1 hole...hard work.My own fault though, because I was too tight to hire or buy a proper core drill. I had to make a 150mm hole through a three brick thick wall.
Core drills tend to be slower, higher torque and no impactWhats the difference between a core drill and SDS drill out of interest? My limited understanding is you dont use the impact function when core drilling if using an SDS drill. Is a core drill just bigger/turn slower or something else? (I just imagined it was the bits - masonary bit vs core bits that made the difference, rather than the machine turning them?)
They are more powerful, low revving have a decent clutch and a long side handle. They do not AFAIK have a hammer action and are too slow to drill small holes.Whats the difference between a core drill and SDS drill out of interest? My limited understanding is you dont use the impact function when core drilling if using an SDS drill. Is a core drill just bigger/turn slower or something else? (I just imagined it was the bits - masonary bit vs core bits that made the difference, rather than the machine turning them?)
I guess thats what confused me as both my small and big SDS drills have the option to turn and not bang, turn and bang and bang but not turn. The small one (parkside and only £40 so cheap) has less torque for sure. The big one (the Titan SDS Max jobby from Screwfix) has more torque than i will ever need (at the moment) and both seem to have clutches and variable speed!SDS drills go bangy bangy, and some turn too.
Core drills go turny turny, and if you are not careful, take you with them.![]()
got a bit carried away with an extra 0 on the endA 13kW drill would also keep you warm in winter.
shoulda been 1300 wJust ordered onebosch multidrill for hard bricks thats all i ever use day in day out , sharpen them twice on a green stone when blunt then chuck em https://www.screwfix.com/p/bosch-ex...dTttqfZWTPYQPp8WQGzO1Fs7aBLClCJsaAvCwEALw_wcB
il give you the 3 quid if your not happy with itJust ordered one
I hope it works it was £3!
Thanksil give you the 3 quid if your not happy with it![]()
Just ordered one
you doIf I recall you don't use them on hammer in brick... ?
i run mine on the 18volt dewalt drill on impact and the higher speed mainly. just give it a good shove
you doi run mine on the 18volt dewalt drill on impact and the higher speed mainly. just give it a good shove
