It'll run static and dynamic tests, dynamic for anything that only produces a signal when the engine's running, a crank or cam sensor for example.So when my diagnostic tool says plug in and turn on but DON'T start the engine it's not necessarily right?
That's interesting as I've sometimes had to start the engine to get it to work.
Here's one from today - Sales vehicle from a trader, been in a few times with DPF issues prior to me working there. It's had a new genuine DPF & soot sensor, the owner only does very short journeys to work & back and has been told she needs to do at least a good 30 minute run every 10 days or so (also should have been told she'd be better off with a petrol car...)That's the key thing that many techs don't get.
Something that always sticks in my mind, is an article in one of the trade mags years ago by their diagnostic "specialist", and the key thing that they stressed was diagnostic kit is just another tool in your toolbox.
It doesn't give you the answers, it simply tells you where the ECU has detected something is wrong. It's up to the tech to actually interpret that information, and diagnose the problem.
As I'm sure you have, I've spent many hours reading tech info to actually understand how something works.
Even for simpler stuff, like understanding how the old Transit 2006 fuel filter head worked, which was a revelation in getting them to bleed reliably.
and if you want to test operation of sensors such as crank & cam. The static test will look at resistance values and continuity, but as you were saying earlier that's only part of the story.The only time that running the engine will make a difference is when triggering actuators or clearing DTC's,
This is the problem I've had when looking for faults! I can see what's being picked up on the reader but don't necessarily know what it should be.other thing is does the person checking know what the input/output should look like?
Is it the sensor the wiring to it or something else?
Agreed - I was referencing the 'plug in and turn on but DON'T start the engine' in the main, although a lot of control modules will block actuator tests if the engine is running.
Sometimes it's useful to compare measured vs. expected sensor values with the engine off and on, for example, pressure sensors should all read roughly atmospheric pressure with the engine off, sometimes it's a good way of detecting things like blocked exhaust back-pressure sensor sample tubes and out of spec differential pressure sensors (most often caused by condensation in the sample lines damaging the pressure cell - it's not just water vapour, it's a weak nitric acid due to the presence of nitrous oxide getting trapped by the water molecules) Sensor tests with the engine running can point to a problem with the engine or a defective/contaminated sensor, but you do need to know the expected range of values.
I really don't know how diag. techs that work in multi-brand environments do it, I've worked for various brands and it can be a challenging time working with just one brand, albeit lots of models and architecture's. Working with maybe five or six brands across a week takes a good breadth of knowledge and the mental agility to make the switch. In theory, they're all similar but the implementation can vary massively.
This one is good, not as broad a scope (!) but freeThe Picoscope guided test site is a good resource - https://www.picoauto.com/library/automotive-guided-tests/
Even better if you have a Picoscope and software and can access their waveform library, but the above should get you well on your way.
Hardest part is usually figuring out where sensors are, or what manufacturers have called certain sensors, and aftermarket diag kit that has parameters reading the wrong thing.I really don't know how diag. techs that work in multi-brand environments do it, I've worked for various brands and it can be a challenging time working with just one brand, albeit lots of models and architecture's. Working with maybe five or six brands across a week takes a good breadth of knowledge and the mental agility to make the switch. In theory, they're all similar but the implementation can vary massively.
I have one and it's pretty much my go to for diagnostics.The Picoscope guided test site is a good resource - https://www.picoauto.com/library/automotive-guided-tests/
That drives me nuts. There's an international scientific language, so why automotive manufacturers all go their own way with names and terms is beyond me. Especially irritating if you're searching for some obscure little part as you have to run through guesses for what it, and what it's fixed to, might be called.Hardest part is usually figuring out where sensors are, or what manufacturers have called certain sensors,
Its all part of the conspiracy to make things more complex than they need to be, so the only alternative is to use main stealer and buy new more often.I have one and it's pretty much my go to for diagnostics.
There's the mechanical engine designers, the electronic control designers and the technical writers - all use different terms, even cylinder numbering mech's use 1-8, elec's use 0-7 tech writers use whatever comes to mind! Some start at flywheel end some from crank pulley end.I have one and it's pretty much my go to for diagnostics.
I don't care, it's been providing lucrative employment for vehicle technicians - in and out of dealer networks - for as long as I can remember.Its all part of the conspiracy to make things more complex than they need to be, so the only alternative is to use main stealer and buy new more often.
The future of unsustainable society, cars will become just like throw away electronics, fridges etc. big business will rule the world and the rest will be poor!
Sometimes on an unfamiliar engine, I'll pull the connection on the sensor I think it is, and check live data and DTC's for the reading to change or the DTC text to confirm....
And without people buying new cars, the supply of 'cheap motoring' used ones would soon dry up and the prices would rocket!
I de plug a lot of stuff - to introduce "an open circuit" code - just to confirm I am looking at the right circuit/sensor.
Almost as much fun as back probing the ECU plugs because there's no pin out data available.
I do the same, and there are quite a few "WTF?" moments especially when the wire colour randomly changes at some point buried in the loom because they've updated the component.Almost as much fun as back probing the ECU plugs because there's no pin out data available.
I've lost count of the number of times I've been offered/told to have the DPF deleted and a remap on the Vivaro.I reckon half the "diesel car park" - at about 7 to 10yrs old has got the DPF/EGR/Adblue/NOX systems tampered with....![]()
