You weren't using the drill in hammer mode, were you?The just look like standard bricks
I had to drill a 32mm hole for a diesel heater exhaust, it took a carbide insert cutter that managed 1/4". A diamond cutter did about 3/4" then fell apart, I chain drilled and chiseled it.
Just need to hang some stuff on the wall
A drill? Was that before you used the explosives - BOOMif its anything like the birkby bricks chain drill it which means use trigger pull but keep the speed down
i had the same issue drilling aberdeen stone had to chain drill it keeping the bit cool which takes alot of time to drill one hole
Bricks are awesome. Even a severe fire in a warehouse stuffed full of cars and the warehouse attached to it next door was fine!British rail used a brick that was harder than anything known to man. we had to put up aerials on some stations and it was a labor of love,
Slow it was like watching paint dry, quality bits Bosch drills nothing phased them lost money on that job.
Never found a brick like them anywhere else
+1. Our house is all engineering brick but I've drilled plenty of holes with a 5.5mm dewalt extreme masonry bit in a dewalt 796 combi drill (only for context, I'm not a dewalt fanboi, it's just what I have). Once the pilot hole is in, you can open up for whatever size plug with a lesser drill bit. I recently had to drill prestressed concrete lintels too and while it struggled on some of the aggregate, it managed it.Best bits I find are Dewalt Extreme 2
