That AI reply is amazing....!
The explanations about your meter charging the capacitors, and the capacitors probably being in series to get the required high voltage rating, etc., are exactly the words I was about to write. I can see that I will soon be out of a job.
I am not sure yet, I need to re-check the troubleshooting results. I am not as fast as Mr./Ms. AII can get a new one from Ali Express exact PN :
Worth a go?
See my thinkingIt has 221v DC when measuring with the correct terminals
See my thinkingC3 + To R2 plus is confirmed at over 200ohms again
See my thinkingWhen powered up C3 measures 161v DC. C4 measures 162v DC. This value stays static or so whilst powered up
See my thinkingWith red probe on gate and SRC- black lead I see only 0V. I restarted the machine at the mains several times over and no change at all. 0.00V steady reading
In Post #49 when you described needing to measure the DC output of the 3-phase rectifier between "-" and R2, and then obtained a value of 221v DC, was that measured on the SR1 component itself, alone, without the small screw-on connector PCB attached?
You then attached the board, and saw 161v and 162v across C3 and C4 respectively?
If so, that is fine because the sum of those two voltages is 323v, which is about the correct result for the peak of 221 volts when smoothed by capacitors ( RMS x square root of 2, i.e. x 1.414 ). The capacitors were connected up when that board was put back on.The two capacitors are in series, and so about half of the DC bus value will appear across each one.
I think the 200 Ohm precharge resistor is R12, right there on that connector board?
See second photo in Post#1 here:
It is odd that after going to the trouble of using a bridge rectifier with a built-in precharge thyristor, Miller have used a relay anyway ( albeit a much smaller one than would have been needed to short the precharge resistor without the help of the thyristor ).
Since the thyristor gate is driven by a relay, the "pulse" will be quite long, and maybe it can be seen on a DVM. In fact, it could even be a steady high.... The trigger signal is positive on the Gate and negative on the Cathode - which is labelled "SCR(-)" on the SR1 rectifier module.
The precharge timer circuit consists of a capacitor C49, Schmitt trigger U9, and NPN driver transistor Q28. This transistor is about 2 inches below the relay in your photo in Post #55, and it looks physically OK. A voltmeter across the Collector ( relay and diode anode ) to the Emitter ( Gnd. ) should show 10 or 12 volts during the initial power-on precharge delay, and then drop to less than a volt after a couple of seconds, when the transistor turns on and the relay pulls in.
P.S. In comparing the 221 volts DC supply with the "160v" bus voltage and calling that "about two thirds", AI does not seem to take into account the difference between RMS and Peak voltages, giving no credit for the even partially-full capacitors....and if this "missing voltage" was all being dropped across the precharge resistor, it would be getting really hot.
