Best get on to Shell Technical.Hello
I have a Broom and Wade AC16 compressor to restore.
What oil is equivalent to Shell Talpa 20?
Hello
Hello 15w40?J'utilise exclusivement de l'huile moteur diesel... et ce, depuis 10 à 20 ans sans aucun problème...
Remplacer mon gros compresseur à piston Broom-Wade coûterait plus de 8 000 £… de quoi s’inquiéter ! J’ai cinq compresseurs fonctionnant avec la même huile, répartis sur différents sites.
en option...
Toutes mes boîtes de vitesses pour tours à métaux et fraiseuses reçoivent l'huile rouge pour boîtes de vitesses automatiques provenant du secteur automobile...
What is the oil capacity of the AC16?I only use a Diesel engine oil.....have done for the past 10-twenty years with no problems.....
To replace my big Broom-Wade piston compressor would be over £8,000....so plenty to worry about..In various locations I have 5 comp running with the same oil...
as an add on.....
all my metal lathes and milling machine gearboxes get the Red automatic gear box oil from the automotive scene...
Hello 15w40?I only use a Diesel engine oil.....have done for the past 10-twenty years with no problems.....
as an add on.....
should only be running at about 1000 rpm topsYes that looks a 1-1 pulley ratio those old compressors won't like 3000rpm
1000 or 1500 rpmI am going to look for another motor
Either. 1500 and a 1-2 pulley ratio would be my choice. Giving around 750rpm pump speed.
