This part of a snowblower. It's a fully threaded 3/8" UNC bolt that holds the impeller onto the gearbox shaft. The shaft and impeller are splined, but the end of the impeller is blank with just thr round bolt hole, the splines aren't visible. There's a heavy round washer under the bolt, and a spring washer.
The bolt works loose. Before the last lot of snow I tightened it hard with impact wrench and it stayed for a couple of sessions but started loosening again.
One idea is to drill through the blade near the root, drill the bolt head, and use lock wire. That (of course) relies on me being able to drill the bolt head.
Or thread lock, but I presume would need some way of degreasing the thread in the shaft.
It's not something that often needs to be undone. If there was anything to key it to then a tab washer would be ideal.
