many_methods
- Croydon, UK
So after finding my handlebars were incapable of turning without brute force, it seemed appropriate not to ride the bicycle until I'd fixed it. So I've disassembled the headset bearings to find them both seized. The top bearing has fallen apart and now the bottom shell of the bearing race is stuck inside the cup mounted in the frame. As the cup is wider than the bearing, I can't strike it from below. Ive tried tapping a screwdriver/wedge in between the cup and bearing also to no avail. The whole thing has been left to soak in a blend of penetrating oil and tears for the last 48hours but it's still stuck solid.
My current thinking is to carefully Dremel a slit through the bearing shell to release the tension and (hopefully) tap it out from there. Any other thoughts before I go at it with power tools?
