Bullet2012
- on average about 200 miles from the ISS.
if its traditional pork pie pastry even that wont be an option.It’s known as a pastry
Very creative, I like it.
Let's hope she doesn't need these
40 Voodoo Pins For Poppet Candles & Dolls Wiccan Pagan Witch Spellcraft Pin Tool | eBay UK
Circle of Magic Pins Set | Ritual Directional Pins | Wiccan & Folk Magic Tool | 35mm Pins. This Circle of Magic pin set is a traditional ritual tool used within folk magic, Wiccan, and spiritual practices.ebay.us
has now confirmed my theory that I can make a flywheel chipper with 7cm blades from it as a next project but also given me the idea of a stump grinder from the other discs in the pile as the cast pin stubs would certainly do the job!
wifey bought some. they were a greasy tasteless blobCommercial/store pork pies are grim. Proper hand made ones cooked by someone who cares about it though are a delight.
even the dog turned its nose up at them . we only buy them from 3 local butchers now and there mint
Decided against the grinder option as vertical blades are the norm it seems you don't get ones like a floor polisher so probably not effective to diy one lol.Please dont - I think it will end badly.
Stump grinders nearly always have carbide teeth as they generally spend a lot of time in the dirt., often trees will encapsulate rocks and stone and takes quite a lot to blunt a stump grinder.
I can see cast discs shattering in that sort of use!
Chippers need a decent mass to them. I'd want the plate to be about 20mm thick steel or it will bend/shatter the first time its used.
Unfortunately local butchers are few and far between, forced out of business by well known mini supermarkets that sell the "greasy, tasteless, blob"we only buy them from 3 local butchers now and there mint![]()
stunning wood that lignum , glad its all working good . nice bowlsHaving spent quite a while improving my home-made lathe, I thought it would be good to give it a test run to prove I hadn't done anything wrong. It turned out I had, but only in that I hadn't tightened up the pair of nuts that set the preload on the bearings, so it turned smoothly for a while and then started to wobble a little. Easily sorted.
Anyway with it running nicely, I started by a quick play (with no particular purpose) with a couple of bits of walnut:
The one at the back was turned with a spindle gouge; the one at the front with two skew chisels. I found it really pleasing that all the bowl making practice last year had obviously paid off: I found it much much easier to turn those spindles than other similar things I tried before.
While I was lathing, I thought I'd turn a few bowls to convince myself I hadn't forgotten how to do it. Again it all went very smoothly:
The biggest one is Brown Oak, the middle one Sycamore and the small one Lignum Vitae (turned out of a bowling ball that had a great big chunk taken out of it so I didn't think it would be much use for anything else). All finished with hard wax oil.
The lathe isn't looking quite as neat and tidy any more
Another spiffing job indeed , I'm still going to like your stuff even though I offered to buy a bowl and you wouldn't sell it to me and then went onto sell at work for charityI made a persuading stick out of a Lignum Vitae Crown Green bowling ball, a stick of Ash and an off-cut of Wenge for the wedge:
That was my first attempt at a mallet and I expect I'll make more: partly because my other half wants one for leatherwork and partly because I imagine that when I try to use it I'll find I'd like to tweak the shape of the handle and perhaps even the head. Nevertheless I was very pleased with it for a first go.
Ooh, I like that !I made a persuading stick out of a Lignum Vitae Crown Green bowling ball, a stick of Ash and an off-cut of Wenge for the wedge:
