Erie Fred
- Erie, Pa USofA
Not really, I did it at my farm also worked at a local garage where we did it in the lot.Yep I found a few but shipping adds another 6-10 on top of that. I'll try calling some blasters local to me to see if they are willing to sell individual bags.
I was concerned of that as well, wouldn't want a cloud of itchy mess like you get when sanding fiberglass, but apparently these turn into literal dust on impact so not an issue in the same way as sanding grp.
I'm sure other members have experience with this and may weigh in, but it's the only thing that makes me reluctant towards air blasting and pushing me towards considering the "300kg of wet sand" scenario of wet blasting.
Have you tried any of them?
@Erie Fred have you found the other bits apart from blast media a big issue in the past?
One year I used 12k lbs of medium black beauty (coal bottom ash) doing large beams.
Both places are "rural" with nobody within 500' at least.
I don't think you are going to remove sealer very well BTW.
Probably blast, and then go back with a knife to remove the sealer that is still hanging on, and then blast the
area under the sealer.
its preferable to keep a constant 90 psi pressure up without dropping otherwise it alters the ratio of media and air and gets less efficient
i instantly put them right and showed them a thin one gallon oil can i had blasted a few times with no blow through and shut them up
