because your not telling the full story its the same with everybody that brings a pc for repairs always expect the customer of lieing
from your own comment 1st post
strangely enough I know exactly what you mean. I used to do tech support for vinyl cutters and so often they never did EXACTLY what was asked or went too quick based on what they knew..
I have an SSD I am unable to boot from (as yet) so I am trying to get as much data from it as I can (after fitting it in the new PC as a SATA drive) BUT it keeps coming up with access restrictions.
but you never said that in your first post and you havent said what operating system that your using
I did actually gaz.
I only use windows so again I assumed thinmgs..lolits not even reaching the OS. just insert correct boot media. But that was not actualkly what I posted about. although I probably confused everyone. lolas goes for mainboard swap amd will swap to amd or it will on mine but im not using windows 10/11 but it wont swap to amd to intel but it will swap from intel to intel when upgrading but that goes to the drivers that are saved within the install files from a non microsoft disk
