I need to reduce from 32mm MDPE barrier pipe to 25mm non barrier and the only effective way to do this looking at the pipe run is using a 90 degree elbow.
I want to use Plasson fittings as everything is buried, not on my land, 15 mins walk across fields and is a pain in the backside if it leaks and Plasson seem to be reliable.
Plasson do a 32-25 straight reducer so I could use that and then a 90 elbow 25-25. But thats four joins when I could get away with two. Plasson dont, as far as I can tell make an elbow that reduces from 32 5o 25mm pipe (other cheaper brands are available though but dont want to use them).
Plasson do make this kit though to reduce within the fitting itself:
This reducing set cant use a pipe insert. Is that a problem with this system and are reducers of this type reliable?
32mm - 25mm Reducing Set www.gasandwaterpipelines.co.uk
plastic pipe supplies
