Buying an ex-private ambulance would tick that box along with it just being a basic van. It's unlikely one is going to get hammered or damaged unless there's been a zombie apocalypse I'm not aware of?
You've missed it. That was last week.Buying an ex-private ambulance would tick that box along with it just being a basic van. It's unlikely one is going to get hammered or damaged unless there's been a zombie apocalypse I'm not aware of?
And enjoy the engine thrashing at cruising speeds, the cruising speed being dictated by the huge brick-like aerodynamics.My favourite for this kind of thing is a small Luton.
alot of the restrictions comes from industry campagning against homemade/diy van conversions as they was taking away money from the selected industryDVLA clamped down on conversions, as a noticeable number of people were 'converting' vans, but then removing the kit and just using them as a normal van to get the higher speed limits.
Guidelines can be found at https://www.gov.uk/government/publi...van/converting-a-vehicle-into-a-motor-caravan
I think the main thing they changed, is you no longer require a toilet.
Makes no difference. I had mine reclassified and its the same. VED is calculated on emissions at manufacture.I may be wrong but I think getting a van reclassified as a camper also means a big reduction in road tax/VED.
I had mine reclassified and It makes no difference.I may be wrong but I think getting a van reclassified as a camper also means a big reduction in road tax/VED.
The only thing that changes is the speed limits and the MOT class
MOT is "as presented";
I was under the impression that a "motor caravan"as described on the V5was a class 4, whilst any other van over 3000kg was class 7?
2.3 Motor caravans
A motor caravan is “a motor vehicle (not being a living van) which is constructed or adapted for the carriage of passengers and their effects and which contains, as permanently installed equipment, the facilities which are reasonably necessary for enabling the vehicle to provide mobile living accommodation for its users”.
Motor caravans are not classed as goods vehicles for MOT test purposes and are therefore in class 4 or 5 depending on their seating capacity but regardless of their size or weight.
VED is calculated on emissions at manufacture for the base vehicle.
The only thing that changes is the speed limits and the MOT class.
it would get rather interesting for many if they started mot for trailers and caravans something they are pushing for for farm trailers which also effects trailers on wagons as wellWhat class a vehicle is tested to (and whether it's a 'motor caravan') is down to the MOT inspector's assessment of the vehicle presented to them (not what's on the V5C) and there's guidance on how to determine this in their manual.
The definition of 'motor caravan' from MOT guidance:
