Richard187
New Member
- Hampshire UK
Hey all! Have found this forum super helpful so thanks for the advice!
I’m several months into welding with my Clarke 120 inverter multi welder
I’m using a 10% CO₂ / 90% Argon mix
I’m butt welding car body panels mainly, I’ll post some pictures below, but I’ll first describe my issue:
1. Inconsistent arc, some sizzles, pops, silence. All over the place, feels inconsistent and a struggle
2. Really easy to blow through
3. Spatter
4. Terribly hard to adjust, just a single dial on the machine. 1mm one way seems too low, 1 mm the other seems too high
5. Inconsistent penetration
6. I don’t know if I’m the problem or my welder is - after-all and good works-man always blames his…
I did some googling and found the following but not sure how true it is:
1. My gas mix ratio might not be ideal
2. The 120 welders low end voltage might not be ideal for a stable arc, a 150 might be better for example
3. The single dial control could mean that it’s mapping of voltage to speed isn’t set best for thin steel
4. The motor may be providing an inconsistent wire speed
What have I done so far:
1. Made sure my gas flow is around 13 with a flow meter (reading on this was very different my swp regulator)
2. Done a tonne of practice welds and found the sweet spot on the dial
3. Made sure the ground is good - always ground back to fresh shiny steel
4. Made sure the tip and shroud are good
5. I’m using 0.6 wire
Would love to hear your thoughts! I mean it’s getting the job done, but when I learnt I learnt on a mightmig and it seemed way easier to get a nice flat weld on thing steel.
Cheers all
3. Spatter
Cheers all
