Yeah, you're quite right, I was perhaps overthinking!No1 det cord should do it nicely.
The technique I was told by a scrapper friend, was to nick the top surface, snap the rest off.Assuming it's used track, the underside will be much softer than the work hardened 'topside'. Cut most of the way through from the 'bottom' and the last bit may actually snap off with a BFH.
How deeply are they embedded into the ground? And how much concrete surrounds the column?
Remove shed, pecker on a digger and just lift out with a machine!they are standing for 50years, before my time, probably down 2ft 6
video or it didnt happenClaymore?![]()
Not to mention damn heavy so maybe use an engine crane or similar to hold the cut off piece upthose things are fierce when they let go
I meant the disc...if you have someone pushing the post away from you and there are no obstructions it's going to get to a point where it just falls away, then when it on the ground you finish the cut off neededNot to mention damn heavy so maybe use an engine crane or similar to hold the cut off piece up
