Happy Christmas everyone and thanks for allowing me to join.
I have a Sip Migmate 100 that has been in dry storage in the back of the pantry for the last 25 years and have just pulled it out as need to put into use.
The problem I have is that the wire feed motor, although on occasions will vibrate when the trigger is squeezed, I cannot get it to rotate properly. It has done the odd little slight movement, but very slowly and only around half a turn.
I've removed the 24V wiper type motor and powers up fine from my Power probe off a 12V battery.
I've sprayed contact cleaner as best I can on the wire feed rotational switch and checked the contact inside the trigger on the torch.
The machine buzzes when the trigger is pressed and that is what can sometimes me felt through the motor.
When the motor does turn a tiny amount it feels juddery.
This machine is almost mint and far too clean to write off.
Your help and guidance would very much be appreciated.
Thanks.
Thanks.
