BrokenBiker
- Newport, South Wales
Freelander is sluggish to start, noticed over the last few days. It will start and is fine once running, will then restart all day just fine.
It has a varta f21 on it now, a dynamic stop start battery, however it was either not told it had a new battery, or it's hit it's limit for stop start as that feature doesn't work, although it will restart if you stall and dip the clutch quickly enough so the system works,it just doesn't want to. Even if it did work I'd turn it off though, hateful system and as much as the car runs fine, I don't trust it what with that green oval on the front.
What are the consequences of just changing the battery for a standard correctly rated battery and just not telling it the battery has been changed?
