RWD3M
- Wiltshire, UK
Hi chaps,
I need to make this:
80 x 40 x 3 box with a couple of 22 x 16 tubes welded inside, then a slot through the whole lot. Getting the tubes into the box are straightforward but the slot is perplexing me just a little.
The slot is about 1/2" wide and about an inch in length. I have a drill press and a small mill (EMCO FB2 clone).
In my head I'm thinking once the tubes are welded in place, punch a 1/2" drill through whole lot on my pillar drill, and then use the mill to turn the hole into a slot. Am I that far off?
I've had a little play with the mill on just a piece of 22mm tubing and TBH, it didn't seem like it wanted to make the holes on it's own. This is likely because I really don't know what I'm doing with it and/or I'm using the wrong bits?
Any light you can shed would be most gratefully received.
