Thrashsmith
Enough to slide off a tightly rolled cylinder?Maybe I should have clarified that the roller isn't totally removable, it can disengage & then can be swung out at an angle to rest into the cradling bracket, which can be see on the left hand side, on the vertical frame.
No because it'd still be trapped between the top pinch roller and the former roller (not visible in the pic)Enough to slide off a tightly rolled cylinder?
How high can that be adjusted? I really cant see why you can't roll the workpiece around the removable roller, there appears to be plenty of vertical adjustment on that roller.former roller (not visible in the pic)
You wouldn't roll anything that large underneath, anything with a large enough radius is elastic enough to be opened up to remove it without permenantly bending it. There isn't a front brace which is another reason I'm sure my thinking is correct.There's bracing bars underneath which would obstruct things from being rolled downwards
Try it.I get the rationale behind thinking it should be rolled down, but I just don't think it works in practice....?
Perhaps a casting is stiffer and allows it, maybe a removable lower roller was required to make it fabricated.
