can_of_worms
New Member
- Sonoma, California
I have a mower that I'm extending the axles about 2 1/2 inches out, and I need to make sure they're absolutely straight. I know about slipping a collar over the joint after welding it, I found this thread: https://www.mig-welding.co.uk/forum/threads/weld-two-steel-rods-together.126984/
the thing is that the rim is a keyed 3/4 inch and it will end up slipping over the joint, so half the original axle is in the hub and the other half supports in and keeps the tire from coming off. Is beveling the two pieces and mating them enough? I will be supporting the axle just before the hub with a pillow block bearing on either side.
Pictures of the mowers are attached (the right side of the photo with the mower has more chamber because I forgot to put the bushing in that side)
I just finished lowering the front and making new spindles for her. this is my first really extensive welding project. I'm 17 and still very inexperienced in the grand scheme of things, so let me know what I'm doing wrong (all of this is flux core, because its so convenient for me)
