...it would need to be close grained, seasoned hard wood
I will do a hand sketch, have never mastered CAD, except for the cerial packet and scissors type, I am dyslexic and cannot get past the set up page for Fusion! I don't think the bulge is necessecary or maybe even original as I will not be moving the axles to their full limits, my body will be mounted lower and so I will probably move the bump stops down a bit,I am not sure wood choice would need to be so restrictive. A stack of MDF might do, cover with a 3mm layer of epoxy or polyester resin, and turn to final profile. Plastic in that size is very expensive, probably very similar in cost to aluminium.
Wood is not messy to turn if you rig up a hoover nozzle near to the tool point.
Do you have a sketch of the profile? How are you to turn the curve on a metal lathe? It might be easier to rig up a tool rest and use some wood turning chisels.
One of the moulds would appear to need to be two piece as the gaiter has a bulge in it. You would have to assemble the outer two piece one over a solid inner one or assemble a collapsible inner one inside a solid outer.
A drawing of the profile would be most useful as then those who do metal casting could tell you what is the best option.
I may look into bonding some MDF into a suitable lump, I don't fancy turning that amount out of an alloy billet, ...............Aluminium would be cheaper than a quality plastic at those sizes
Might even be cheaper to sandcast the things, out of something of no particular grade of alloy....Aluminium would be cheaper than a quality plastic at those sizes
I will do a hand sketch...
Can you cast something 9 1/2" round with a 4" hole, 3" deep, if so what sort of cost, I have alloy wheels and other alloy scrap suspension parts, some new, best I do a sketch, between nursing duties!Might even be cheaper to sandcast the things, out of something of no particular grade of alloy....
Wax polish a lot, certainly works for GRP moulding. I painted my moulds with celly hi build primer.Buy a sheet of MDF and cut it out with a jigsaw, glue / screw together, finish turn in the lathe. Then varnish and polish to seal the mold.
Volume needs to be below 1.5 litres, ideally.Can you cast something 9 1/2" round with a 4" hole, 3" deep, if so what sort of cost, I have alloy wheels and other alloy scrap suspension parts, some new, best I do a sketch, between nursing duties!
