they were brazed on , so they will un braze the same way , the straight one looks like a re usable hydraulic fitting anyway
what condition is the rubber part in , you could get the whole thing made up maybe ,,, just thinking outloud ,,,
Be very careful with the banjo, i was recently caught out by a pitted one.Thanks, the banjo fitting is also re usable its plently strong still just pitted in some areas.
I would have to note the clocking of that pointed fitting to be sure the original hose doesnt end up misalingned.
seemed ok but ended up with fuel pi$$in everywhere from a pinhole
Given the condition of the rest of it I think it would be foolish not to fit new hoses.
As for the brazing - you need to heat up those fittings to red heat and hold them there whilst you feed the brazing rod and pull the braze down into the joint.
That takes quite a lot of heat. It will greatly help if you can knock up a temporary forge to encapsulate the heat. Firebrick is ideal but paving brick or patio slabs work too if you don't hold the heat directly on them.
I see these ones look correct and ill try to order these to NI
Type 9081 Weld on Metric Banjo Soldered or Brazed
Type 9081 Weld on Metric Banjo suitable to use with metric pipe Fitting has to be soldered or brazed These Connectors are USED for Air Water Gas Oilwww.advancedfluidsolutions.co.uk
That way one or both banjo fittings can be renewed.
Ill take it to RT autoparts and see what they say RE new hose. I dont know if the male fitting in my photos is standard. I guess if they dont have that they could use other fittings to create a new hose section if I bring them the new kunifer pipe sections pre bent and the new banjo fittings brazed on.
Before brazing anything I would bolt on the banjos and dry assemble the whole thing with the kunifer pre bent and your rubber hose tightened up.
With everything clipped in place make clear alignment marks between the pipe and the fittings so that you can braze it in the correct orientation.
Hydraulics can go with a bang and it all depends on what's near them when they failwhy would it be like an explosion ,,,, thats got me curious ,,,
Ah , I thought the incompressibility of fluids would have prevented exactly that , as in why fluids used in vessel pressure testing to avoid such things happening , all you get is a squirt .Hydraulics can go with a bang and it all depends on what's near them when they fail
Brazing is the way to go.....just a thought about kunifer if your still thinking of that...the wall thickness is going to limit the max pressure it can handle. There's no doubt it will "work" everything else being equal in normal operation...... just remember that the system is designed at higher max pressure than the kunifer will take......the alternative?....trying to hand bend steel pipe in complicated runs is a pita....
Practically, I'd probably do the same as you though![]()
I assume, an 8 mm OD pipe would be 0,008 m.While I appreciate your concern on gut feel, it feels a touch sensationalist in the context of some maths (also 200 bar is knocking on 3000psi).
Google reckons silver solder will develop somewhere between 70 and 250MPa in shear depending on silver content. Feels about right, so assume worst case, but consider both. Assuming an 8mm OD pipe and some decent high silver solder, that means you need a joint length somewhere between 1.6mm and 5.7mm. That's to react 200bar, which exceeds the 190bar PRV set pressure, not the 50bar normal operating pressure.
I'd be quite confident of making a fully wetted 8-10mm long silver solder joint, but if you're concerned, make some test pieces and section them to make sure you can do it repeatably.
Standard disclaimer - this is merely opinion, not advice.
Cunningham's law in action!I assume, an 8 mm OD pipe would be 0,008 m.
That just pop into my eyes, haven't checked or calced the other columns.
I'd probably try Kunifer as well, but design pressure for even 1mm thickness 8mm steel pipe is 333bar-The kunifer tubing I have is rated for 120 bar. I believe it will be fine and im using it.
If it bursts then Ill know it was not fine
