Strange@johngb
I assumed they were the original motors and pulleys as they were all identical. However, now I look at the speed chart again only 8 speeds are listed (for each mains frequency) which doesn't correspond with a five-step back-geared drill, for which you'd expect to see 10 speeds.
Yea most probably.It could be meddings offered different pulley and speed options from the standard.
Were they 1 phase or 3 and what was output 6plyI found some old photos. These motors were taken from my bank of meddings drills. Check the pulleys...
3 Phase. Probably 0.55 kWWere they 1 phase or 3 and what was output 6ply
Thanks 6ply. Gona start looking for good quality 1phase 1kw motor. Don't know if i should go old or new yet3 Phase. Probably 0.55 kW
You really don't need 1 kW.Thanks 6ply. Gona start looking for good quality 1phase 1kw motor. Don't know if i should go old or new yet
.5 or.75 kw then ?You really don't need 1 kW.
Thanks for info 6plyLarger motors will be d90 frame or similar, with correspondingly large spindles. 24mm won't be convenient to you.
